LabWindows/CVI
LaunchExecutableEx and NotePad - again
This question was answered, but did not make sense to me. Will someone else give it a try?
Can I use the LaunchExecutableEx command to launch notepad.exe, but make notepad automatically open a specific file that is stored in a variable in my program?
(3,202 Views)
The answer is yes. The function panel help for the Filename parameter of LaunchExecutableEx shows an example of this.
Copy the following code into the interactive execution window and run it. Create a file named C:\temp.txt.
#include
#include
#include "userint.h"
static char *filename = "c:\\temp.txt";
static char *viewer = "notepad.exe";
static char buffer[(MAX_PATHNAME_LEN * 2) + 1];
sprintf(buffer, "%s %s", viewer, filename);
LaunchExecutableEx (buffer, LE_SHOWNORMAL, NULL);
Hope this helps,
David Rohacek
(3,202 Views)
