LabWindows/CVI
Launching command line compiler
I would like to use Launchexecutable to launch the command line compiler. When I try this is seems like the compiler starts up, but the parameters are not getting passed. (the project to compile)
to simplify I put the project in the same directory and the command.exe program:
This works when I run it on windows using the command line utility "RUN":
"C:\Program Files\National Instruments\CVI71\compile" "autogen.prj"
However these do not work:
            LaunchExecutableEx("""C:\\Program Files\\National Instruments\\CVI71\\compile"" ""C:\\Program Files\\National Instruments\\CVI71\\autogen.prj""",LE_SHOWNORMAL,&handle);
            LaunchExecutable("""C:\\Program Files\\National Instruments\\CVI71\\compile"" ""C:\\Program Files\\National Instruments\\CVI71\\autogen.prj""");
            LaunchExecutable("C:\\Program Files\\National Instruments\\CVI71\\compile autogen.prj");
            LaunchExecutable("""C:\\Program Files\\National Instruments\\CVI71\\compile"" ""autogen.prj""");
(4,291 Views)
in order to help debugging this: write a simple executable that accepts and display the command line parameters. something like:
int main( int argc, char *argv )
    printf( "%i arguments passed:\n", argc );
    for ( i = 0; i < argc; i++ )
        printf( "%i: {%s}", i, argv[i] );
    return 0;
now use LaunchExecutable to run the resulting exe and see what it is receiving as parameters. it should give you a hint on what's going on with your call.
(4,262 Views)
Have you tried using:
    LaunchExecutable("cmd /c C:\\Program Files\\National Instruments\\CVI71\\compile autogen.prj");
JR
(4,232 Views)
Or try:
LaunchExecutableEx("\"C:\\Program Files\\National Instruments\\CVI71\\compile\" \"C:\\Program Files\\National Instruments\\CVI71\\autogen.prj\"",LE_SHOWNORMAL,&handle);
(i.e Use a backslash to escape a double-quote within your string.)
Mert A.
(4,221 Views)
