LabWindows/CVI
Library function error (return value == -60 [0xffffffc4])
hi everybody, i'm trying to start my timer but this error is poping as an NON-FATAL-RUN-TIME-ERROR while the command line is running.
SetCtrlAttribute (panelHandle, PANEL_TIMER, ATTR_ENABLED, 1);
miki
(5,225 Views)
That's very strange: error -60 means "the control must be a list control", it has no connection with a timer!
Are you sure the line of error is that one? Have you checked that the panel handle refers to the panel the timer is on? Can you decode ATTR_ENABLE value? (place a breakpoint on the line and when the program stops on it hover the mouse on the label and note down resulting value).
Which version of CVI are you using? Are you developing in CVI or are you using VS or another compiler? Are you developing a standalone exe or a dll?
(5,203 Views)
i found my problam, thank you a lot!
(5,176 Views)
