08-11-2008 05:54 AM
08-11-2008 08:18 AM
For a similar task I created a blank canvas which was the same size as a numeric slider control. Set to a transparant background and overlaid in the same place as the slider, you can then use CanvasDrawLine() to produce a suitable marker.
JR
11-10-2010 04:01 PM
Is there a way to do this while making the marker location variable? I'd like to set a reference marker that will automatically update it's location on the slider with the ambient air temperature in my app. Thanks
11-11-2010 02:52 AM
This red line is a second Tank with everything hidden, no fill and I made the fill translucent ontop of the first. This way the red line moves with changing the value of the control, and CVI takes care of the scaling.
11-11-2010 12:14 PM - edited 11-11-2010 12:24 PM
Tank?? Do you mean the slider? How did you make one of them translucent? I can't find a reference in the LV 8.6 help. Thanks
11-11-2010 12:42 PM
I just noticed that this may be the wrong forum for my post. It's the only one that came up after a search. I'll try posting in another area. Thanks.
