LabWindows/CVI
Link error in the example FM Signal Generation For PXI-5670 and PXI-5671 in LabWindows/CVI
Hi.
I'm trying the follwing example:
http://zone.ni.com/devzone/cda/epd/p/id/2618#0requirements
and I get the following error:
Inconsistent type declarations for external symbol '_Get_pComplexData@4'...
I installed the most recent Modulation Toolkit for CVI 9.0.1
On another PC with an older version of 'Modt.h' the example compiles and works.
Can you please explain me what the error is?
I appreciate your help on this issue.
Regards.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
(3,449 Views)
Sorry for the late reply.
Can you say me what version of Modulation Toolkit for CVI do you use?
Can you also post your project with all file (I can't find exampleMemAlloc.h and exampleCntlUtil.h).
Thanks for the file.
Yann C.
France
(3,383 Views)
Hi Yann C.
I'm using Modulation Tookit version 4.1, 2009.
My project is based on the example so I'll just send you to the example webpage:
The files you need come with the modulation toolkit and are attached to this post.
Thank you for your reply.
Daniel Coelho
(3,373 Views)
