LabWindows/CVI
Linking Fortran objects into a CVI project
I have some trouble linking a fortran object to a CVI project. I managed to build a DLL (with corresponding *.h and *.lib files) from the fortran sources using g77, gcc and link.exe from MSVC.
The functions prototype is:
#define ECGPU_REAL double
void inicializa_cero_(ECGPU_REAL *iondat,
        ECGPU_REAL* iqtc,
        ECGPU_REAL* iqrspa,
        ECGPU_REAL* iqrsmw,
        ECGPU_REAL* iqrs,
        ECGPU_REAL* iondaq,
        ECGPU_REAL* iqt);
When linking my CVI project I get the following error message:
  Undefined symbol '_inicializa_cero_' referenced in "analyse.c".
This indicates in my humble opinion a problem with the name mangling. CVI expects functions to have a '_' prefix while link/g77 doesn't procedure a underscore for fortran functions.
Is there any solution for this dilemma?
Christian
(3,501 Views)
You could always try adding your own '_' to the function name in the source code and rebuilding the dll.
JR
(3,490 Views)
Smiley Happy
Doh, you are right, silly me!
Using
inicializa_cero__ (with a double underscore at the end) solved my problem.
Thanks!
BTW: I used "nm" (from cygwins binutils) to get the exact name of the function symbol.
(3,486 Views)
