LabWindows/CVI
Linking GPIB Instrument address to CVI
Here is a tutorial to assign names to GPIB resources.
http://www.ni.com/getting-started/set-up-hardware/instrument-control/gpib-connect
S. Eren BALCI
IMESTEK
Message 11 of 14
(571 Views)
I could be wrong but I believe that is for VISA aliases and they are for use with the NI-VISA API but ibfind() works on a much lower level as it is the GPIB API itself. NI-VISA lays on top of that and uses the GPIB API to communicate with GPIB instruments.
Rolf Kalbermatter  My Blog
Message 12 of 14
(565 Views)
Yes, that's right. If MAX is used for assigning logical names then VISA library (viOpen, etc) should be used instead of low level functions.
S. Eren BALCI
IMESTEK
Message 13 of 14
(556 Views)
Did some digging today. I changed the scope address to 10 but the ibfind is still returning 5 (old address).
I used NI-MAX to update the configuration and I could see visaconf.ini change to match what I was changing in NI-MAX. Still couldn't get CVI/C- to find the new address.
I read about ibconf and configuring the GPIB with this tool but I do not have it on the PC.
Also when I go to Start->National Instruments->NI-488-2->Explore GPIB it complains that niroot.nce cannot be loaded. Measurement & Automation is not properly installed. Do I need this?
It wants me to reinstall Explore GPIB but I do not have the disks.
Message 14 of 14
(545 Views)
