LabWindows/CVI
Linking to C++ DLL
I am trying to link to a C++ DLL.   The DLL includes a lib and header file.
However, when I try to compile I get "Warning: Empty Declaration" error
#define dllexp __declspec( dllexport )
#define dllimp __declspec( dllimport )
extern "C" {
 //see descriptions and examples in call8v.cpp
 dllimp short DsoDetect(unsigned char* CfgBuffer);
 dllimp void ExitDSO(unsigned char* CfgBuffer);
Ive attached a screenshot of the project.
Thanks in advance.
Diego
(3,798 Views)
extern "C" is a C++ specific feature to compile/reference functions with C linkage from C++ code. It is meaningless (an an error) in C programs.
The normal way to work around this (as the extern "C" is absolutely necessary in C++ programs building or using the DLL) is to exclude instances of extern "C" except in C++, using the preprocessor.
You can see this for yourself if you look at the headers CVI installs; from userint.h:
#ifdef __cplusplus
    extern "C" {
#endif
and
#ifdef __cplusplus
#endif
If you wrap this opening line and its closing brace in these guards, it should solve your problem.
-alex
(3,786 Views)
Alex,
Thanks very much for your quick response.
Yes, U are correct and it did work.
Diego
(3,752 Views)
