LabWindows/CVI
List Box error:out of range
Hi everyone:
   Thank you for your attention.
I am using List Box Control to display test information, but occur error, the hint is out of index range.
I list part relative code for you, maybe you can find some clues and help me .
#define TEST_STATUS_MAX_SIZE ((long) 102400)
long GUI_TestStatus_Write (char *svalue_in)
 long lreturn = GUI_ERR_NONE;
 int ilist_item_count = 0;
 if (iMainPanelHandle > 0)
      lreturn = (long) GetNumListItems (iMainPanelHandle, MAINPANEL_LISTBOX_TESTSTATUS, &ilist_item_count);
      if ( ilist_item_count > TEST_STATUS_MAX_SIZE )
      { //max data allowed exceeded. clear window.
               lreturn = (long) ClearListCtrl (iMainPanelHandle, MAINPANEL_LISTBOX_TESTSTATUS);
       lreturn = (long) InsertListItem (iMainPanelHandle, MAINPANEL_LISTBOX_TESTSTATUS, -1, svalue_in, 0);
     if (AUTOSCROLL_ENABLE == iAutoScroll)
               if (ilist_item_count >= 1)
                 lreturn = (long) SetCtrlIndex (iMainPanelHandle, MAINPANEL_LISTBOX_TESTSTATUS, (ilist_item_count-1));
 return lreturn;
the system break down in SetCtrlIndex (), i do not know how to resolve it
Thank you in advance!
(3,219 Views)
Duplicated post: see here
(3,213 Views)
Thank you,'
 I think when the list box is full (102400 item) the error occurs ,which occurs one time about 16 hours ,  i have tried to reset ilist_item_count to zero. and see tommorw's result.
Thank you very much
(3,208 Views)
