LabWindows/CVI
ListFindItem using CStringCompare
I am trying to use ListFindItem to search a List for a string.
Using ListFindItem (List_Watch, car_number, FRONT_OF_LIST, 0);  will not find a match that I know is there.
THen I tried using ListFindItem (List_Watch, car_number, FRONT_OF_LIST, CStringCompare); but got the following error Fatal Run-Time Error 'General Protection Fault'
I do not know if I am formatting the CStringCompare call correctly and can not find example.
I really do not know while it is not working with the original attemp of just using"0".  The string I am comparing is "63"  loaded into car_number (char car_number[10];)  and I know it is in List_Watch because I also laod List_Watch into a List Ring and I can see the string 63 in it!
(3,930 Views)
Hello altronics,
So regarding your two questions, so instead of passing 0 as the compare function in ListFindItem (which causes CVI to do a memcpy on the two strings), you can pass the CStringCompare function which will perform a strcmp comparison on the two strings.
The reason why you are getting a fatal run-time error when you pass CStringCompare as the compare function is most likely because you are not passing a null terminated string or a large enough array into the Item to Find parameter of the ListFindItem function.
So I wrote up some sample code, which works on my end.  It should help you reformulate how you are calling the ListFindItem function.  Hope it helps.
#include "toolbox.h"
int main (int argc, char *argv[])
    char *dog = "dog";
    char *cat = "cat";
    int result;
    ListType newList;
    char *itemToFind = "cat";
    newList = ListCreate(sizeof(char *));
    if (newList)
        ListInsertItem(newList, &dog, END_OF_LIST);
        ListInsertItem(newList, &cat, END_OF_LIST);
    result = ListFindItem (newList, &itemToFind, FRONT_OF_LIST, CStringCompare);
    return 0;
Wendy L
LabWindows/CVI Developer Newsletter
(3,884 Views)
if you pass an array to the functions, you will get this error. It must be a pointer.
Regards
Frank_deSmiley Happy
(3,850 Views)
