LabWindows/CVI
ListType as parameter of a DLL-function from C#
I have a dll written in CVI, I should use the functions in C#. My problem is, that in some functions there is a list (ListType) as parameter.
CVI function definition:
int DLLEXPORT InserInList(ListType listSendRequest, char *cRequest)
Code in C#:
[DllImport("DLL_Test.dll", EntryPoint = "InsertInList", CallingConvention = CallingConvention.Cdecl)]
public static extern int InsertInList(List<RequestItem> listRequest, string Request);
DllImport("DLL_Test.dll", EntryPoint = "InsertInList", CallingConvention = CallingConvention.Cdecl)] public static extern int InsertInList(ArrayList listRequest, string Request);
I've tried two kinds of implementation in C#. With the first one an exception will be thrown, that generic types can not be marshaled. The second option runs at least without an error through, but the list in C# stays empty. Is there any chance to pass a list as a parameter to a dll-function?
Thanks.
(5,064 Views)
Hello Shaq,
You can't just pass .NET types like that. I guess what you're trying to do won't work. Your DLL has to create a new instance of the list which is then returned to the caller (your .NET application).
AFAIK the ListType is some sort of pointer to a hidden structure so you may just use IntPtr to store references to that list.
The PInvoke code should probably look like this:
public static extern int InsertInList(IntPtr listRequest, string Request);
Of course you need to retrieve a reference to an actual list object which is exported by your DLL.
ListType DLLEXPORT CreateList(void);
[DllImport("DLL_Test.dll", EntryPoint = "CreateList", CallingConvention = CallingConvention.Cdecl)]
public static extern IntPtr CreateList();
Hope this helps.
regards,
kkeller
(5,000 Views)
