LabWindows/CVI
Load file
How can I load a data file in to my program to update Global Parameter when I start run program ? It mean that I don't change my program. When I want to change some value in Global Parameter I will adjust in Data file ( it will auto update in to Global Parameter Table) ? Pls help me to do that.
Thanks !
(3,308 Views)
Variables globat to the application or configuration options are usually loaded at startup but can be reloaded upon request taking values either from a file on disk or from the registry. I discussed this options in this thread that you may use as a reference for your needs.
(3,301 Views)
