LabWindows/CVI
LoadMovableCtrlSettings gives Invalid Control ID Error
Hello
I am calling the function LoadMovableCtrlSettings which is giving an Error ie Invaild Control ID when i pass a handle which returned by NewPanel function.
Piece of Code:
first save the settings
SaveMovableCtrlSettings (ActivePanel, -1, "custctrl"); //Saved moveable control settings
then called
 newpanelID = NewPanel(0,panelHandle,"Animation",50,50,700,1000) ;
DisplayPanel(newpanelID); //Works fine till here
 cnt = LoadMovableCtrlSettings (newpanelID,2,"custctrl"); //Gives error: Invalid Control ID. Why???????????
Looking for help...
Rakesh
//Also tried with DuplicatePanel,LoadPanel but same error.......
(3,011 Views)
Rakesh,
It looks like your error is complaining because you are passing 2 as the ID of the control to load settings for, when your panel actually has no controls on it. LoadMovableCtrlSettings will not add controls to a panel, but instead is meant to apply settings previously saved for a particular control (or controls) on a panel. If you want to apply the settings from the file to a new panel that you create, you will need to use LoadPanel to create the new panel; this will ensure that the control IDs of the newly-created panel are the same as the ones saved by SaveMovableCtrlSettings.
Hope this helps.
Mert A.
(3,003 Views)
