05-16-2005 09:46 AM
05-17-2005
03:28 PM
- last edited on
08-12-2026
06:34 PM
by
Content Cleaner
You will be able to implement a solution close to what you describe, but not exactly as stated in your post.
The LoadLibrary SDK function is used to load and unload DLLs programmatically. You can find more documentation on this function in this document on MSDN.
As you can see in the documentation there is a limitation with loading the a DLL with the same name multiple times: "Two different modules cannot have the same file name, even if the extensions are different. These effectively have the same module name. For example, if LoadLibrary is made on Sample.cpl, the operating system will not load Sample.cpl, but instead will again load Sample.dll."
If you create a separate DLL file for each instance you would like to open you can use something similar to what is described in Knowledge Base 2EIBT1Y1 to create function pointers that will allow you to execute a function in each DLL.
Scott Y
NI
05-17-2005 04:05 PM
