LabWindows/CVI
Loading with moving image
Hi, I have a request.
I have a panel on the image that is loaded when I start the program, it works as it should, but I would like to insert or change a slider to animate the image (for example, a plane that flies or a dog that runs), how should I proceed?
do i have to use canvas for it?
Thank you for answer
(1,513 Views)
Dear MajklS,
I've found a youtube video that does the animation. You can create the animation as it is in the video and write a separate logic for the speed of the animation that suits you. Here's the link : https://www.youtube.com/watch?v=QAI_E1cmEuY&ab_channel=RashidMalik.
Best,
Anasei.
(1,491 Views)
