LabWindows/CVI
Local variable initialization
How local variables initialized in CVI?
Are there any default values for local variables?
(4,777 Views)
Local variables are not initialized as default. You have to do that with your code.
(4,772 Views)
Following function is generated by IVI Scope driver generator.
If the vertical coupling is GND, variable simOffset is used in an equation without being initialised.
Is this a bug and it must be initialized?
* Function: TTTTT_FetchWaveformSafe
* Purpose: This function returns the data from the instrument. You must
* range-check all parameters and lock the session before calling
* this function.
static ViStatus TTTTT_FetchWaveformSafe (ViSession vi, ViConstString channelName,
ViInt32 waveformSize, ViReal64 waveform[],
ViInt32 *actualPoints, ViReal64 *initialX,
ViReal64 *xIncrement)
ViStatus error = VI_SUCCESS;
if (!Ivi_Simulating (vi)) /* call only when locked */
ViSession io = Ivi_IOSession (vi); /* call only when locked */
ViChar rdBuf[5000];
checkErr( Ivi_SetNeedToCheckStatus (vi, VI_TRUE));
/*=CHANGE: ==============================================================*
Do actual instrument I/O only if not simulating. Example:
viCheckErr( viPrintf (io, ":WAV %s:DATA?", channelName));
viCheckErr( viRead (io, rdBuf, 5000, VI_NULL));
Change the number of elements in the rdBuf array as appropriate for your
instrument's maximum record size.
Convert the rdBuf raw data here to a double precision floating point
numbers and store the data in the waveform array.
Read the waveform preamble from the instrument to get the initial X
and X increment values.
If the oscilloscope did not resolve all points in the waveform record,
replace such points with the IVI_VAL_NAN value. The function should
return the TTTTT__WARN_INVALID_WFM_ELEMENT
warning in this case.
*============================================================END=CHANGE=*/
else
ViInt32 x;
ViReal64 yRange, simOffset;
ViInt32 triggerSlope, vCoup;
ViReal64 k, level, theta, offset;
checkErr( Ivi_GetAttributeViInt32 (vi, VI_NULL,
TTTTT_ATTR_HORZ_RECORD_LENGTH,
0, actualPoints));
checkErr( Ivi_GetAttributeViReal64 (vi, channelName,
TTTTT_ATTR_VERTICAL_RANGE,
0, &yRange));
checkErr( Ivi_GetAttributeViInt32 (vi, channelName,
TTTTT_ATTR_VERTICAL_COUPLING,
0, &vCoup));
TTTTT_ATTR_VERTICAL_OFFSET,
0, &offset));
TTTTT_ATTR_TRIGGER_SLOPE,
0, &triggerSlope));
checkErr( Ivi_GetAttributeViReal64 (vi, VI_NULL,
TTTTT_ATTR_TRIGGER_LEVEL,
0, &level));
TTTTT_ATTR_HORZ_TIME_PER_RECORD,
0, xIncrement));
TTTTT_ATTR_ACQUISITION_START_TIME,
0, initialX));
theta = asin (2*level/yRange);
if (triggerSlope == TTTTT_VAL_POSITIVE)
k = 1.0;
else
k = -1.0;
if( *actualPoints>waveformSize )
*actualPoints = waveformSize; /* Checking number of points to write */
*xIncrement /= *actualPoints;
if (vCoup == TTTTT_VAL_DC)
simOffset = 0.5;
if (vCoup == TTTTT_VAL_GND)
k = 0.0;
for (x = 0; x < *actualPoints; x++)
ViReal64 y = simOffset + k * 2.5 * sin (*xIncrement * 12560 * x + k * theta) + // ~2 periods of 1kHz sinewave
(!(x%20)) * (16384 - rand())/150000.0;
waveform[x] = (offset + yRange/2) > y ? ((offset - yRange/2) < y ? y : (offset - yRange/2)) : (offset + yRange/2);
Error:
return error;
(4,767 Views)
Eddie,
It does look as though the simOffset variable is not initialized unless the coupling is set to GND. To clarify, were you seeing an error saying the variable isn't initialized?
(4,741 Views)
I haven't seen an error yet, just was wandering how the function will react in this case and is this an error that should be fixed?
(4,729 Views)
Eddie,
If you do see an error, you could change the variable declaration to the following:
ViReal64 simOffset = 0;
This would resolve any errors that may occur. Let us know if you have any more questions about it!
(4,716 Views)
