LabWindows/CVI
LocalUI via cmd or ActiveX-Interface?
I have a bigger workspace with quite a few Dll's, which had to be translated to German, French, Spanish ... The creation of lwl-files has to be done for each dll, after each (small) change, so I look for a way to do this automatically. Is it possible to call "localUI.exe" via command-line (what parameters?) or is there an activeX-interface?
Thanx
Peter
(3,331 Views)
You cannot call localUI.exe by command line parameter or use activeX.
You can however open up the *.lwl files with a text editor and change them. I think this would be a good solution.
Best regards
Benjamin
(3,287 Views)
