LabWindows/CVI
Localizing UI with tabs - assert error
If I call LoadLocalizedPanel in CVI 8.0 to load my panel with native tabs I get the following error:
Assert!
Programming error detected.
The error was detected on line 1643 of 'uiobjects.c'.
Program aborted.
I did use the "User Interface Localizer" tools to create an lwl file, and it seemed to work fine.
But the plot thickens: When I merely load the TabExample.uir file from ...\cvi80\samples\userint\  into the "User Interface Localizer" tool, I get the same error!
Help!
--Ian
(3,567 Views)
Ian,
This is a known issue in CVI 8.0. Tab controls are not working with the localization tool.
There will be a patch coming out soon that will correct it. I'm sorry about this...
Luis
NI
(3,554 Views)
Thanks, Luis. I'll watch for that.
Fortunately it's not a big issue for me - I can revert to unlocalized operation for the short term.
--Ian
(3,546 Views)
