LabWindows/CVI
Localizing UI
In CVI 5.5 is a fine tool UI localizer.
In UI Localizer utility the panels and menu bars are localized ok.
When I run the program panels are localized as they should be.
But Menubars are still in default language.
sample code:
handle.logset=LoadPanel(0,"Logger.uir",LOG); // Loading panel
LocalizePanel (handle.logset, "fi.lwl"); // Localizing panel
/* Loading localized menubar */
LoadLocalizedMenuBar (handle.logset, "Logger.uir", LSETUP, "fi.lwl",
&menuHandle);
also tried
menuHandle = LoadMenuBar (handle.logset, "Logger.uir", LSETUP); //
Loading menubar
LocalizeMenuBar (menuHandle, "fi.lwl"); //
Localizing menubar
Has anybody use localized menubars? Should it work or is there a bug?
Kari
NOKEVAL Oy HTTP: www.nokeval.com
Kari Yli-Tuomi Tel. +358-3 342 4823
Yrittäjäkatu 12 Fax. +358-3 342 2066
37100 Nokia, Finland Email kari.yli-tuomi@nokeval.com
Message 1 of 1
(3,322 Views)
