LabWindows/CVI
Locking software after xxx days
I need to deliver my code to users which wouldn't run after xxx days or after it has run xxx number of times. Looking for third party libraries which will integrate with CVI. Would be nice if this library also gives me the ability to lock out certain features of my CVI application. The users would be asked to enter a code (based on which machine they installed it) which I will email to them.
(3,949 Views)
I've implemented a simple solution is CVI as an .fp and .dll that you can call.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,935 Views)
How simple it is? I know I can come with somthing but don't want which is easily crackable. Can you post (if possible) what kind of algorithm you used. Thanks.
(3,930 Views)
Anyone doing something like this?
Anothe rthing I would like to add in my application would be "Software Registeration/Activation", like NI does for CVI. Where the user woul dbe required to enter a registeration code (online or offline) and then the application only runs on that particular PC.
Any suggestions?
(3,877 Views)
Unfortunately, CVI's application builder is not very powerful. You can create basic installers and control the location of the install and such. For more complex installs (like the ones you are describing), it is best for you to use a 3rd party install creator such as WinInstall or AppDeploy.
Jack J.
(3,839 Views)
Here is a link if anyone else is interested.
(3,797 Views)
