LabWindows/CVI
Lost Comport Error
I have an application that connects to a device through the USB port with a USB to Serial Converter.  So the Port is treated as a comport say COM 1.  Everything works good I can open, close, read and write to the Comport.  But the problem comes in if the port gets disconnected and then I try to read from it.  The application locks up or shuts down.  This happens becuase the USB - Serial converter is viewed as a comport and then disapears when it is unplugged.  Is there anything I can do to verify that the comport is still there prior to doing a read/write or what would be the best method to handle this error?
(3,665 Views)
I guess at the very least you could always close it and then re-open it.
Check the return value on the re-open to see if it is there.
(3,644 Views)
I have actually added functionality to verify that it is still there right before I read to the data, but it still happens that it errors out during the read.  I would have expect labWindows to handle it gracefully and just report the error, but it doesn't seem to be doing that.
(3,618 Views)
Does it say that the com port is available even if you have the USB-Serial converter disconnected?
Rasheel
(3,601 Views)
