LabWindows/CVI
Low Level Support driver not found
Well, That's OK, Thank you!
Message 11 of 16
(2,099 Views)
Hi helloPete,
From what I understand, the use of the inp and outp ( functions in CVI are not useable on 64 bit operating systems).
Brandon Grey
Certified LabVIEW Architect
Message 12 of 16
(2,083 Views)
Thanks for the answer. I have given up the try on 64bit system, and reinstall my PC to Win7 32bit. So far the program works fine but waste my new 8G memory. 😞
Message 13 of 16
(2,070 Views)
Hi, Haywac, this issue was solved or not? I repeated the same problem you observed, I installed different release packages of Win7 32bit system, some release can work fine with the CVILowLevelSupportDriverLoaded command and return 1, someothers returned 0. I think there must be some different between the win7 32bit releases. or caused by different windows updates, who knows. really an aweful story on this command.
Message 14 of 16
(2,052 Views)
I don't know why you want to use the paralle port and what you intend to use it for, but if I were you I'd search for any alternative that doesn't rely on inp and outp.
As of my experience, 32-bit systems are becoming a rarity and several systems on the market don't even have a parallel port onboard. Additionally, I don't feel happy in having to unnecessarily run an application with administrative privileges. Considering that several cheap digital I/O boards exist, I wonder if purchasing one of them isn't better than spending time in installing/configuring/testing/modifying the systme without warranty it can be actually used and survive periodic OS updates.
Message 15 of 16
(2,044 Views)
Thanks for the answer. About 10 years before. I use this function to achieve about 1MHz pulse to realtime control a step motor. Recently, I tried three kinds of PCI boards, they all use command instead of realtime pulse control. Have to goback to this old function. Will try the other solutions.
Message 16 of 16
(2,040 Views)
