LabWindows/CVI
Macro redefinition compile time error
#define FOO       1
#define FOO       0.9
I had the above definitions in my code and cvi didn't complain while compiling, I thought it would, Can someone explain?
Thank you
(3,282 Views)
To get a warning for this you need to enable "Macro redefined" warning.
Options>>Build Options. Click on the "..." button in Compile Warnings section and check "Macro redefined" in Compilers Warnings dialog.
(3,247 Views)
