LabWindows/CVI
Maintain aspect ratio on panel re-size
I think it would be valuable to have a panel attribute "Maintain aspect ratio on resize" that would apply to manual resizing (not maximizing) a panel.
I know this is doable with panel callbacks and EVENT_PANEL_SIZE but a native solution that shows that constraint while dragging a corner would be better.
And given the nature of many of our UIs I think this would often be used.
Any comments before I submit a product suggestion?
--Ian
(4,513 Views)
It is a very good suggestion. I agree with you, this function should be native.
(4,498 Views)
This is possible using the EVENT_PANEL_SIZING. This method shows the constaint while dragging the corner or side of the panel. Check out the attached example program.
(4,472 Views)
That is much nicer to see the constraint live, rather than have the window unexpectedly snap to a different size after releasing the mouse button.
While a simple checkbox for the panel attribute would have been ideal, this solution works for me.
Thanks, Jared!
--Ian
(4,443 Views)
I realize that this topic is very old; however, this example in LabWindows does exactly what I would like to do in a LabView GUI.  If anyone could suggest how to do this in LabView, either natively or through a call to a DLL based upon this LabWindows example, I would greatly appreciate it.
Jason
(3,829 Views)
Since this is now a LabVIEW question, I would recommend to post it in the LabVIEW forum!
The event structure has a "This VI...panel resize" event and you can probably use it to enforce a certain aspect ratio.
(3,823 Views)
