LabWindows/CVI
Make invisible a menu item
i want to know if there is a simplier way to make invisible a menu item or submenu than in discard it and recreate it after.
Thanks.
(3,144 Views)
Two things I can think of:
- You can dim the menu item
- You can copy the whole menu into another menu, delete the items you want to be invisible and switch between these menus with SetPanelMenuBar.
(3,128 Views)
You can also call DiscardMenuItem() to remove the menu item completely, but then you will have to re-create it if you want to add it back.
Bilal Durrani
NI
(3,117 Views)
