LabWindows/CVI
MakeDir Succeeds, but GetFileInfo immediately after
I called GetFileInfo to determine if a directory existed and it did not. I then created several directories, one below another, successfully with MakeDir. I then called GetFileInfo on the directory and got an exception saying access to the file was denied. This is all in 1 program run. I can see the directory get created with Win Explorer. Why am I being denied access to the directories?
(3,075 Views)
Not really sure, but did you look at the permisions on the directory created?
What's the permissions of the user logged in running the program?
I am assuming CVI used the logged in use permissions to do theses tasks.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,067 Views)
I figured it out. Dumb Mistake specifying the directory name. The permissions were fine.
Thanks.
(3,058 Views)
The other issue was that I should have been using FileExists(), NOT GetFileInfo(). Seems bizarre. Oh Well.
(3,051 Views)
