LabWindows/CVI
Manual for COMpnp_read?
A contractor wrote some PXI serial port code for me and used COMpnp_read() and other COMpnp_xxxx() functions for the serial PXI port card.
I am familiar with VISA, but that doesn't look lie a VISA call to me.
What is this COMpnp_ package and where is the manual for it?
(2,794 Views)
That looks like custom code to me. When working with instrument drivers, you'll typically see in the C APIs a prefix before any of the function calls that references the instrument that you are using, ie hp34401a_xxxx(), tdstks2xx_xxxx(), etc. If you use an auto generation tool to create your base code for an instrument driver, often times you have the option to define the prefix, then generate a group of generic functions, such as prefix_read(), prefix_write(), etc.
My recommendation would be for you to contact the developer who gave you that code. If they do not know what it is, please repost, and we'll see what we can find.
Logan S.
(2,775 Views)
