LabWindows/CVI
Maps and LabWindows
Is it possible to plot real maps (e.g. U.K or whatever) with CVI, providing I get a map database (such as used in GPS terminal for example)?
(4,305 Views)
That sounds easy enough, just get a picture to use as a map, and import it as a picture. You will need to probably know a set of coordinates on the map, that will let you know the scale. There are ways to return the current pointer location (x and y) in the picture as well.
(4,274 Views)
Bitmaps would be easy, but would give you limited functionality.
You may want to look into an ActiveX mapping object like MapInfo MapX.
Click here to browse through a google search.
(4,271 Views)
Thanks. I think this should help me. The picture solution doesn't allow me some functionnalities I need:
- rotation
- focus
- translation
(4,263 Views)
