LabWindows/CVI
Maximum number of lines
Hi.
I need to know what is the maximum number of lines in a list box or a table in CVI.
I need to know if my application will break if it's active a very long time.
Thanks.
(3,274 Views)
It depends on which version of CVI you're using. For a listbox, up until version 6.0 the maximum was only around 2-3K, depending on the size of the font. After version 6.0, it should be pretty much unlimited (well, around 2 billion). For a table, the maximum number of cells is supposed to also have been around 2 billion, but there is a problem when highlighting cell ranges beyond the 32k range. This will be fixed in the next version of CVI.
Luis
NI
(3,260 Views)
Just keep in mind: Having thousands of lines in a listbox starts to reduce its useability. I wouldn't expect most users to scroll through that much data and find anything meaningful very efficiently.
(3,244 Views)
