LabWindows/CVI
Measure the time of an operation (LabWindows)
i used LabWindows/CVI to transfert a waveform (in my oscilloscope) into my computer. I would like to know the time with precision for this operation. Can you give me the fonctions for that.
Thank you and bye.
(5,360 Views)
The most precise timer available from the system is just a millisecond timer. You can use the Timer() function to determine elapsed time using the system clock. For example,
double timeStart = 0, timeElapsed = 0;
timeStart = Timer();
timeElapsed = Timer() - timeStart;
If you need more precision than milliseconds, you will have to find some way to use the CPU for timing or use a timing plug-in device (PCI card).
Best Regards,
Chris Matthews
(5,360 Views)
Thanks Chris for your answer,
i use this code and the answer is timeElapsed=0.2060000000. But this time is in seconds or milliseconds?? Because if this time is in milliseconds the transfert rate is not respected!!
(5,360 Views)
That is in seconds. So, 206 milliseconds is the elapsed time.
(5,360 Views)
Ok, I prefer.
(5,360 Views)
If you need really precise timer AND if your processor is a Pentium AND if you plan to recompile your code with MSVC you could do as follow :
At the top of your source code type in
#ifndef _CVI_
#define MyRDTSC(var)\
__asm _emit 0x0F \
__asm _emit 0x31 \
__asm mov DWORD PTR var, eax \
__asm mov DWORD PTR var+4, edx
#endif
Somewhere in a callback where you need to measure a timing
int CVICALLBACK OnBlablabla (int panel, int control, int event, void *callbackData, int eventData1, int eventData2){
#ifndef _CVI_
__int64 i64_start, i64_end, i64_diff;
#else
time_t t1, t2;
#endif
#ifndef _CVI_
MyRDTSC(i64_start);
#else
t1=clock();
#endif
MyTestFunction(void);
#ifndef _CVI_
MyRDTSC(i64
_end);
i64_diff = (i64_end - i64_start);
sprintf(cMsg, "Processing request : %d µP cycles", (int)(i64_diff & 0xffffffff));
#else
t2=clock();
sprintf(cMsg, "Processing time : %d ms", t2-t1);
#endif
return(0);
Doing so you should be able to compile the code either under CVI or MSVC and take advantage of a very precise timer whenever it make sens.
Regards, Philippe
Feel free to visit http://www.baucour.com
(5,360 Views)
Thanks for your answer
(5,360 Views)
