LabWindows/CVI
Memory leak from DAQmxReadAnalogF64 ??
Hello all, I've been chasing a memory leak all week, and it appear that the call to DAQmxReadAnalogF64 is the issue.
We're using a PCI-MIO-16XE card, Win7, CVI & Vision 2009.
The code works fine all day, but we're attempting 24-7 fatigue tests now, and it bombs after ~22 hours.  😞
I tried my project on a trial verison of CVI 2013, same results.  So I scribbled up a simple test to verify, and it does the same thing.
What am I doing wrong here?
Did I find a problem with DAQmx?
Attached should be the 3 files needed to build the test.
Start Windows Task Manager, run the code, and watch the memory ratchet up.
Could someone verify please, I'm losing sleep over this one.
Paul
(4,627 Views)
Doh!  Pilot error.
Replaced:
DAQmxRegisterSignalEvent(DAQmx_Val_SampleCompleteEvent);
with
DAQmxRegisterEveryNSamplesEvent(DAQmx_Val_Acquired_Into_Buffer);
and all works fine...
 When in doubt, RTFM  (and review the examples)
Paul
(4,606 Views)
