LabWindows/CVI
Memory leak using tooltips on child panel
I noticed the memory used by my program was increasing at about a once per second rate. Then I noticed it would only increase when the mouse was over a child panel with some indicators on it. The indicators were all created using the DuplicateCtrl function and tooltips assigned using SetCtrlToolTipAttribute. I then created a short program to verify that it was the tooltips causing the problem.  Is this a bug or am I using tooltips wrong? Here is my test program (also attached).
#include "toolbox.h"
#include <cvirte.h>
#include <userint.h>
#include "ttmemleak.h"
static int hMain, hTestPanel;
void CreateIndicators(void);
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                       LPSTR lpszCmdLine, int nCmdShow)
    if (InitCVIRTE (hInstance, 0, 0) == 0)
        return -1;    /* out of memory */
    if ((hMain = LoadPanel (0, "ttmemleak.uir", MAIN)) < 0)
        return -1;
    if ((hTestPanel = LoadPanel (hMain, "ttmemleak.uir", TESTPANEL)) < 0)
        return -1;
    DisplayPanel (hMain);
    DisplayPanel(hTestPanel);
    CreateIndicators();
    RunUserInterface ();
    DiscardPanel (hMain);
    return 0;
int CVICALLBACK MainHandler (int panel, int event, void *callbackData,
        int eventData1, int eventData2)
    switch (event)
        case EVENT_GOT_FOCUS:
            break;
        case EVENT_LOST_FOCUS:
            break;
        case EVENT_CLOSE:
            QuitUserInterface (0);
            break;
    return 0;
    int i, iTop = 10, iLeft = 50, iCtrlID;
    char szBuff[40];
    for(i=1; i<=80; i++){
        iCtrlID = DuplicateCtrl (hMain, MAIN_NUMERIC, hTestPanel, "", iTop, iLeft);
        sprintf(szBuff,"Tooltip #%d",i);
        SetCtrlToolTipAttribute(hTestPanel,iCtrlID,CTRL_TOOLTIP_ATTR_TEXT,szBuff);
        iTop+=20;
        if(i%20==0){
            iLeft+=100;
            iTop = 10;
I have a numeric control on the MAIN panel and am duplicating it 80 times on the child TESTPANEL panel.
Using CVI 8.1.1 on XP.
(3,690 Views)
Thank you for reporting this, and for making an independent test program that shows this behavior.  I also see this behavior.  This was reported to R&D  for further investigation.  Thanks for the feedback!
Cheers,
David Goldberg
Software R&D
(3,669 Views)
Hi.
I noticed the same trouble with CVI 8.1.1. it seems that this trouble is solved with CVI 8.5, could you confirmed me ?
thank you
Jean Philippe
(3,366 Views)
hello
it's me again. I found the answer this bug is fixed with CVI 8.5
jp
(3,364 Views)
