LabWindows/CVI
Menu bar with item propertie checked
I have an item in the menu with the properties checked activated. I do not manage to have the properties of checked. Do I have to use GetCtrlVal and SetCtrlVal to get and set the propertie checked ? At each time the user click on this menu entry, I would like to change the status of checked/not checked.
See the attached file.
Thanks for the support.
Message 1 of 10
(5,238 Views)
1) in the UI editor you set the initial attributes, i.e. when the program starts up your menu item will be checked.
2) If you want to change an attribute (dimmed, checked,...) at run time, you can use the function
SetMenuBarAttribute ( menu_bar_handle, menu_item_id, ATTR_CHECKED, 0 (or 1) );
Note that you are a setting an attribute (hence the name Set...Attribute), not a value; also you want to address a menu (hence the name SetMenuBarAttribute) and not a UI control Smiley Wink
Message 2 of 10
(5,236 Views)
... and if you want to change the attribute every time a user clicks on this menu entry, you will need to use a menu callback such as
void CVICALLBACK EnableFMCLogFileMenuBar ( int menuBar, int menuItem, void *callbackData, int panel )
    fmc_log = !fmc_log;
    SetMenuBarAttribute ( menuBar, menuItem, ATTR_CHECKED, fmc_log );
    return;
Message 3 of 10
(5,233 Views)
Ok, I want to use GetMenuBarAttribute to get the status : here is my code
void CVICALLBACK EnableFMCLogFileMenuBar (int menuBar, int menuItem, void *callbackData,int panel)
int Value;
Value = GetMenuBarAttribute(menuBar, menuItem, MAIN_M_BAR_FMCLOG_LOG_FMC, &Value);
At execution, I have the following error message : "The attribute passed is not valid"
I dot not know what use for attribute instead of MAIN_M_BAR_FMCLOG_LOG_FMC
Message 4 of 10
(5,230 Views)
Obviously, your function call is wrong as it does not contain a valid attribute....
Your MAIN_M_BAR_FMCLOG_LOG_FMC is not an attribute but probably your menuItem...A valid attribute, for example, is ATTR_CHECKED, so the function call should look like:
GetMenuBarAttribute ( menuBar, menuItem, ATTR_CHECKED, &Value );
Message 5 of 10
(5,221 Views)
I have tried, but I have always Value = 0 (whatever the initial configuration checked or not)...
Message 6 of 10
(5,219 Views)
That's because of a second mistake: you assign Value twice...as attribute, and as status:
Value = GetMenuBarAttribute ( menuBar, menuItem, ATTR_CHECKED, &Value );
so in this case Value = 0 means that the function returned without error (at the price that you overwrote your attribute value) Smiley Wink
So change it so something like:
status = GetMenuBarAttribute ( menuBar, menuItem, ATTR_CHECKED, &Value );
Message 7 of 10
(5,214 Views)
I am wondering if your question got resolved. If so, you could mark one of my answer as the solution, thanks.
Message 8 of 10
(5,203 Views)
Accepted by topic author sfla
Ok, I was on vacation. It works now ! Thanks a lot for your help !
Message 9 of 10
(5,201 Views)
You're welcome - but as a side note, you should have marked the post that solved your problem, not your own thank you Smiley Wink
Message 10 of 10
(5,198 Views)
