LabWindows/CVI
'Mesa.dll could not be found' received from CVI 2010 installation
Hi vix,
Check out this thread. The problems with Mesa dependencies is one of the 3 problems described there.
Until this is fixed, you should be able to correct it by adding these merge modules to your distribution:
   C:\Program Files (x86)\Common Files\Merge Modules\Microsoft_VC90_CRT_x86.msm
   C:\Program Files (x86)\Common Files\Merge Modules\policy_9_0_Microsoft_VC90_CRT_x86.msm
Luis
Message 11 of 13
(5,657 Views)
Thanks Luis.
Your suggestion fixed the issue.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 12 of 13
(5,647 Views)
I have the same problem with getting the mesa.dll message on the customer's computer.
Just want to share with you that I only did the 3rd step and the problem was resolved.
The VS 2008 C++ runtime package can be installed at --
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&dis...
-Chee Chong
Design Engineer
Message 13 of 13
(5,573 Views)
