LabWindows/CVI
Mesa.dll could not be found
After getting GPIB-ENET/100 working on my system, went to run Labwindows and immediately got the following error: "Mesa.dll could not be found" I checked and it is located in C:\Program Files\National Instruments\Shared\Mesa. Not sure what to do, nothing works now.
(7,029 Views)
There are a couple of things to test, first try opening CVI by double clicking on a project file; different from the one that CVI is loading. It is possible that the specific project that CVI loads automatically is causing the problem.
If this does not helps, then you can go to the Add/Remove Programs applet, select NI software and repair the installation of CVI. This process makes sure that all the required files are up and running. this should fix any possible issues with the actual DLL.
Please give this a try and let me know how this goes.
Juan Carlos
N.I.
(7,030 Views)
Hi Juan,
The second option you recommended fixed the problem (repair thru add/remove programs applet).
Many thanks !
Rich
(7,029 Views)
I am glad this is working now. this was probably a fluke during the installation.
Let us know if you have any further questions.
good luck with your project.
Juan Carlos
(7,029 Views)
(6,931 Views)
