Dear Mr. Kobayashi,
It has been a long time since I have written to u about Labview. I would
like to ask you a favor to help look for the *.vi file that i used to send
to you about 2 years ago when I had a question about Labview. The title of e-mail should be
(Reference#9361-PX7843) Automated Triggering using computer clock. I am now working on a different subject now but
another student is interested and currently working on that same project that I used to work on. I don't have the VI file that i used to write anymore because it was in the old computer that has been now replaced with a new one. If you happen to have that file available, could u please send it to me. Thank you so very much for your help.
Sincerely,
_Wonsiri
> Hi Wonsiri,
> Hey no problem. Hope your project works out well!
> I had a chance to run that program I sent you and I think my logic was
> backward for the case statement. Just so you know. But the idea is
still
> relevant!
> Best Regards,
> Aaron Kobayashi
> Applications Engineer
> National Instruments
http://www.ni.com/support>
> Dear Mr. Kobayashi,
> Thank you very much for your kindness. I appreciate your help. I must
admit
> that I
> haven't looked at it in detail. However, I am sure that it must be the
> answer that I
> have been looking forward to.
> Wish you the best,
> -Wonsiri
> > Hi Wonsiri,
> > I was unable to load your vi completely because I did not have the
> > driver
> > installed, but I was able to get the idea.
> > Normally we don't write code, but I decided it would be easy to create
> > something to show you how you could do it. I have not tested that
> > attached
> > program so you will have to play with it if you want to get it to
> > work,,
> > but it should give you an idea of how you might go about creating a
> > comma
> > separated text file you could then import into excel. Hope this helps
> > you
> > out Wonsiri!
> > Best Regards,
> > Aaron Kobayashi
http://www.ni.com/support> >
