LabWindows/CVI
Microcontroller socket programming with CVIwindows
I am working on a project where a computer with CVIwindows GUI will be a server and my clients will be DS80C410 networked microcontrollers which has an inbuilt ethernet stack. The comm protocol will be TCP using socket programming. How do I develop socket programming on CVI to get the communication between microcontroller and CVI server?
SR
(5,655 Views)
Here is an article I've found about socket programming in CVI. I hope this can get you started. (Most relevant section of article is toward the bottom)
http://zone.ni.com/devzone/cda/tut/p/id/3067#toc9
Product Support Engineer
(5,632 Views)
Hello James,
Thank you for your reply. I read the GetHostTCPSocketHandle() but not sure how will this work with our microcontroller. If you have any example code or any documentation it would help us a lot and I can purchase CVI for our development. Waiting for your reply.
Sandeep.
(5,624 Views)
I've attached an example c file for a multiclient TCP server from the shipping examples of CVI. CVI includes a TCP and a UDP library and you can add expanded functionality using the subroutine you mentioned. There's also some basic information on TCP programming in CVI in that document I linked in my first response.
Also you can get a 30 day trial of CVI here:
http://digital.ni.com/src.nsf/websearch/70C455BB6564DEC986257880005141F8?OpenDocument&node=node=203014_us
I hope this answers your questions.
(5,598 Views)
Thanks James. I have understood the multiclient server example shipped with CVI. I will try to write the application and will let you know how that works out.
Sandeep.
(5,594 Views)
Try zeroMQ.
(5,060 Views)
