LabWindows/CVI
Minimum distribution files for CVI 8.5
I have a small program (250 kb including embedded UIR) under LabWindows/CVI 8.5. The program simply communicates with an instrument over the RS232 port.
I need to install it on a PC which has no other NI software.
A distribution kit generates 160 Mb!
What is the smallest set of distribution files to get it to work?
Can I assemble this manually?
Or can I link whatever runtime components are used to obtain a (small) self-contained executable?
-Hans
(2,985 Views)
Hi Hans
You will need to install LabWindows/CVI Run-Time Engine and properly also either NI-VISA or NI-Serial driver depending on which function calls you made from CVI.
Unfortunatly there is no possibility to create a distribution only related to your project at the moment. If you think this is a good idea, I would recommend you to vote for some of the ideas on NI Idea Exchange (www.ni.com/ideas)
Best Regards
Anders Rohde
National Instruments Denmark
(2,973 Views)
You can also get the size down some by unselecting the parts of the CVI Run Time engine that you do not need for your application.
(2,963 Views)
