LabWindows/CVI
Minmize and Restore App
I'm working with Labwindows/CVI 5.0 and Windows 2000.
I'd like to take control of the minimization and restauration of my App but I haven't found a way. After I call 'MinimizeAllWindows()' I have my app minimized on the taskbar, up to this everything is fine. Then I have tried unsuccesfully 2 things to control the restauration of it:
First I tried to know when the user clicks on the minimized app on the taskbar, to know when it is restored, but it doesn't seem to produce any event. I tried and wait for this events: EVENT_PANEL_SIZE, EVENT_PANEL_MOVE, EVENT_GOT_FOCUS, EVENT_LOST_FOCUS and EVENT_LEFT_CLICK but none of them seemed to be generated when the app was restored.
At last I tried restoring the app from outside, via CODE in a secondary thread, but I didn't find any function which I could use to restore it. I tried 'MakeApplicationActive()', with no result. Then I tried getting the App Window Handle ('GetCVIWindowHandle()') and sending it a message to restore (SW_RESTORE), but it also didn't work.
I would appreciate any commen or help on this topic.
Daniel
Mensaje editado por Comadreja
(3,386 Views)
Comadreja,
What you can try is to intercept the windows messages.
Look at the functions under User Interface Library >> Callback functions >> Windows Interrupt Support.
RegisterWinMsgCallback might do what you need,  it registers a callback function that LabWindows/CVI calls when your application receives a specific Windows message. RegisterWinMsgCallback returns the actual number of the Windows message.
I messed around with messages a couple of years ago to try to mimic key and mouse events for other applications, it's not easy and not very well documented.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,372 Views)
