LabWindows/CVI
Missing UIR event when using Visual Studio DLL
I used LabWindows 6.0 to create an instrument driver DLL and soft front panel UIR application.  I just ported the DLL over to Visual Studio 2005 and now my UIR has problems.
In Edit->Panel, I set the "Close Control" to a"Hot" control.  When the panel is closed using the CVI DLL it fires an EVENT_CLOSE to the panel callback and then an EVENT_COMMIT to the control callback.  Using the Visual Studio DLL I onle get the panel callback.
(3,279 Views)
Hi bbwpdad,
Did make sure to create your obj or source file for External Compiler Support with the latest version of your UIR file?  I think the first thing I would try is to rebuild that by going to Build>>External Compiler Support and click create, then replace that with the one in your project.
I tried this out using CVI 8.5 and had no problems.  If you are still having problems tomorrow I can try it in CVI 6 to see if there are any differences, but I think it should be about the same.
Kristen
(3,257 Views)
