LabWindows/CVI
Missing class help in FP generated help file
Under LabWindows/CVI 5.5.1 and 6.0, when generating the help file (all formats), the class help are missing in the generated documents.
This really annoying as those class help may contains valuable informations which comes to be quite expensive to duplicate in every functions.
(3,079 Views)
Hello
Looks like there is no automated way of doing this. I will suggest this to our developers to see if we add this feature in future CVI versions. Meanwhile, you might try editing the help file generated by using a tool like the Help Workshop.
But this is a manual process.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,079 Views)
