LabWindows/CVI
Missing file error while creating distribution
Hey,
since yesterday i get an error every time i try to build a distribution. The error says "*** Error (-32): A file, directory, or other data could not be found."
Error Snapshot
A few month ago the build worked find and i think i don't changed anything. I also tried with another project, but the same error occurs. I am using CVI 2012.
So, could someone help me?
Thanks, Stefan
(3,464 Views)
I have done some tests. The error occurs only if i add the "Shared Run-Time Engine" in the distribution settings.
Distribution Settings
(3,420 Views)
Hey,
i could limit the problem a bit.
If i deselect one of the features under the "Shared Run-Time Engine" the build works fine. But it is equal which feature i deselect.
Has anyone got an answer?
Regards, Stefan
(3,351 Views)
