LabWindows/CVI
Missing terminating Null
I just created this function, it will get a shared variable with   CNVGetScalarDataValue (statDa, CNVString, &throughputStat); and strcat another string to it and then write it back.
But I am having this message : Missing terminating Null in string argument and it is pointing to throughputStat.
Any help here? Thank you.
void SendMessg(char *messg)
 int strlenMessg;
 int strlenThroughputStat;
        strlenMessg = strlen (messg);
        CNVCreateScalarDataValue (&statDa, CNVString,"");
        CNVRead (tPutStat, CNVWaitForever, &statDa);
        strlenThroughputStat = strlen (throughputStat);
        throughputStat = malloc(strlenThroughputStat + strlenMessg +1);
        strcat(throughputStat, messg);
        CNVCreateScalarDataValue (&statData, CNVString,"");
        CNVSetScalarDataValue (statData, CNVString,throughputStat);
        CNVWrite (writer, statData, CNVWaitForever);
        Sleep(100);
(5,875 Views)
strlen expects a pointer to a NUL-terminated string - so you need to make sure that before calling strlen your string is NUL-terminated...
(5,866 Views)
 You are overwriting the memory allocation done by CNVGetScalarDataValue() with a new allocation by malloc().This allocation does not point to the same address.
I'am not sure if you can use realloc on memory allocated by CNVGetScalarDataValue(). So do something like
char * help;
CNVGetScalarDataValue (statDa, CNVString, &help);
      strlenThroughputStat = strlen (help);
       sprintf( throughputStat,"%s%s" ,help,messg);
      CNVFreeMemory (help);
(5,865 Views)
What I am trying to do here is that, a shared variable "throughputStat"  is being created (a labview vi will use is as a message receive) . So time to time I have to get hat veriable back concatenate another string message to it (string " *messg") and write it again with CNV write...
so read throughputStat, concatenate *messg to it and write the message back... So the strcat part seems to give me trouble.
This is what I am trying to do.
Thanks for further help.
(5,856 Views)
I think you need to create another shared variable for writing back the information. You can't use the same variable to write back, as long as you need a bigger size.
Just to make clear again: The malloc()  overwrites the pointer that points to to the memory area containing the throughputStat string by another pointer pointing to uninitialized memory,which doesn't need to contain any ASCII 0 character as string terminator.
(5,833 Views)
Wrong thread...
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(4,485 Views)
