LabWindows/CVI
Modification attributes by code
Hi everybody,
I'd like to know how can I modify the size, the font, text color...of a
control by code.
Thank you for yours answers.
(3,314 Views)
Try the "SetCtrlAttribute" function.
Something like this:
SetCtrlAttribute (panelHandle, PANEL_CONTROL, (the attribute you want to change), (its value -depends of the attribute) );
Type "SetCtrlAttribute". Position your cursor on it. Make a "Ctrl+P". A function panel will popup. Click on "Control Attribute", another popup panel will appear. You will find everything you need there. Control and text options. Choose your Attribute Constant, by double clicking on it. For example for the size of the control, you will have something like this:
SetCtrlAttribute (panelHandle, PANEL_CONTROL, ATTR_WIDTH, 150); //ctrl width = 150 pixels
and so on for evrythinfg you want to do...
bye, flo.
(3,314 Views)
