LabWindows/CVI
Modify a file's 'title, comments, or keywords'
I'm trying to modify the properties of a file such as Title, Subject, Author, Category, Keywords, and Comments programmatically through CVI. Does anyone know how to access these?
Thanks in advance
(4,062 Views)
to clarify, I'm talking about ANY file, not just a Word/Excel file that CVI has ActiveX fp's for.
(4,061 Views)
Try this (this one sets a comment which reads "Comment added here" to a file whose path is stored in fileName):
(add ole32.lib to project as statically linked library)
#include "ole2.h"
WCHAR wcFilename[1024];
IStorage *pStorage = NULL;
IPropertyStorage *pPropStg = NULL;
IPropertySetStorage *pPropSetStg = NULL;
PROPSPEC propspec[1];
PROPVARIANT propvarWrite[1];
HRESULT hr;
IID riid;
const FMTID fmtid = FMTID_SummaryInformation;
setlocale( LC_ALL, "" );
i = mbstowcs(wcFilename, fileName, strlen(fileName));
setlocale( LC_ALL, "C" );
wcFilename[i] = 0;
riid = IID_IPropertySetStorage;
hr = StgOpenStorageEx(wcFilename, STGM_READ STGM_SHARE_DENY_WRITE, STGFMT_FILE, 0, NULL,NULL, &riid, (void **)(&pStorage));
hr = pStorage->lpVtbl->QueryInterface(pStorage, &riid, (void **)&pPropSetStg);
hr = pPropSetStg->lpVtbl->Create(pPropSetStg, &fmtid, NULL, PROPSETFLAG_DEFAULT, STGM_CREATESTGM_READWRITESTGM_SHARE_EXCLUSIVE, &pPropStg);
propspec[0].ulKind = PRSPEC_PROPID;
propspec[0].propid = PIDSI_COMMENTS;
propvarWrite[0].vt = VT_LPWSTR;
propvarWrite[0].pwszVal = L"Comment added here";
hr = pPropStg->lpVtbl->WriteMultiple(pPropStg,1,propspec, propvarWrite, NULL);
hr = pPropStg->lpVtbl->Commit(pPropStg, STGC_DEFAULT);
hr = pPropStg->lpVtbl->Release(pPropStg); pPropStg = NULL;
hr = pPropSetStg->lpVtbl->Release(pPropSetStg);
pPropSetStg = NULL;
The available properties to set are:
{"Title", PIDSI_TITLE},
{"Subject", PIDSI_SUBJECT},
{"Author", PIDSI_AUTHOR},
{"Keywords", PIDSI_KEYWORDS},
{"Comments", PIDSI_COMMENTS},
{"Template", PIDSI_TEMPLATE},
{"LastAuthor", PIDSI_LASTAUTHOR},
{"Revision Number", PIDSI_REVNUMBER},
{"Edit Time", PIDSI_EDITTIME},
{"Last printed", PIDSI_LASTPRINTED},
{"Created", PIDSI_CREATE_DTM},
{"Last Saved", PIDSI_LASTSAVE_DTM},
{"Page Count", PIDSI_PAGECOUNT},
{"Word Count", PIDSI_WORDCOUNT},
{"Char Count", PIDSI_CHARCOUNT},
{"Thumbnail", PIDSI_THUMBNAIL},
{"AppName", PIDSI_APPNAME},
{"Doc Security", PIDSI_DOC_SECURITY}
(4,023 Views)
Thanks. Works great.
I do have a followup question though. Can the method you posted be used to modify the file's 'Category'. The const is PIDDSI_CATEGORY but it's value is 0x02 which is the same as PIDSI_TITLE. So there must be another method of changing the Category. Any thoughts?
(4,002 Views)
I believe that the constants that start with PIDDSI will need to use fmtid set to FMTID_DocSummaryInformation vs. the FMTID_SummaryInformation that we have here.
(4,000 Views)
