LabWindows/CVI
Modifying PWM of 6602 in CVI while running
I am trying to continuesly change the PWM signal off counter zero of a PCI-6602
I have the following at start which works:
 DAQmxCreateTask ("", &PWMHandle);
 DAQmxCreateCOPulseChanFreq (PWMHandle, "Dev2/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, 50, exh_pos);
 DAQmxStartTask(PWMHandle);
But how do I modify the duty cycle without stoping and restarting it?
I am running a servo(20ms pulse) and in the Device Exlorer Test Panel, the duty cycle of 4 gives me something and in the programme, everything else the same, the duty cycle of 4 gives me a different position(and so I conclude a different PWM duty cycle) .
Amin
(3,530 Views)
I have found the following function
     DAQmxWriteCtrFreqScalar(PWMHandle   ,1,10.0,pwmfreq,exh_pos,NULL);
And this is what is done in one of the samples!
However during runtime it gives an error "no output in the channel" ?
Any leads?
Message Edited by Amin Ahmadi on 05-31-2007 09:51 AM
(3,514 Views)
Hi Amin,
From your description, I don't see anything that would be causing this problem.  Is there an error code that goes along with the along with the "no output" text?  If you could post the error code and exact text of the error, that may help locate the problem.
Luke
(3,498 Views)
Thanks Luke, I did figure out what to do with it,
For the record and benefit of those wh might search later:
as I found from another thread a link to which I wish I had not lost here is what needs to be done:
 DAQmxCreateCOPulseChanFreq (PWMHandle, "Dev2/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, pwmfreq, exh_pos);
 DAQmxCfgImplicitTiming(PWMHandle,DAQmx_Val_ContSamps,1000);
without the imlplicit timing function, it assumed a finite loop or something like that and therefore does not like to change the PWM duty cycle.
So it works now
(3,481 Views)
