LabWindows/CVI
Monitoring data of APS-7300 AC Power Source using NI-MAX
As indicated in the user manual of the AC power source, NI-max has been used to enter that device. Now, I am confused about whether this Ni-MAX software can be used in monitoring the data and can able to send data to the Excel sheet to save for backtracking. Also, could the PC be my device to do monitoring? or could I use other devices like COMPACTRIO to do monitoring? Lastly, could NI-max be used to print data?
(1,490 Views)
No! NI-Max is a configuration utility for NI hardware and software. It also provides several interactive interfaces to communicate and test these hardware devices but interactive means you can start them and generate different actions interactively but not automate things.
For that you would need some software programming. Depending on the communication interface this could be LabVIEW, LabWindows/CVI, Measurement Studio or Instrument Studio, or if you rather prefer to use some other non-NI software there are possibilities with Python, .Net and several others. It's theoretically even possible to do it directly from VBA in Excel but that is anything but trivial and you get pretty much no support from anyone with this nowadays.
Rolf Kalbermatter  My Blog
(1,441 Views)
