LabWindows/CVI
Mouse cursor during pressing a questionmark button
i have included a questionmark button at the titlebar of a panel. I have used the following function from the Windows SDK for this:
SetWindowLong((HWND)Handle, GWL_EXSTYLE, WS_EX_CONTEXTHELP );
When i click on the questionmark button the mouse cursor should change to the questionmark cursor form the windows sdk, but i have still the normal mouse cursor!
When i move the mouse very fast, i see that the cursor is changed for very short time. I think LabWindows is rechanging the cursor to the default mouse cursor of the panel.
Is there a way to avoid LabWindows from changing my mouse cursor?
Thank you
stefan
(3,307 Views)
You'll have to change the panel's cursor yourself whenever the user clicks on the button. You can do this using the following function call:
SetPanelAttribute (yourPanel, ATTR_MOUSE_CURSOR, VAL_QUESTION_MARK_CURSOR);
Luis
NI
(3,307 Views)
thank you for your Answer. I have already tried this but there is a little problem:
I can only catch WM_Messages from the Windows SDK. In the CONTEXT_HELP-style of a window the Windows SDK sends only a message (the WM_HELP message) when i click with the modified mouse cursor somewhere in my window. So the problem i can not catch the event clicking on the questionmark button self. Or is there a way or a WM-Message to catch this event too? (I haven't found anything in the MSDN)
Stefan
(3,307 Views)
Stefan,
I haven't tried it myself, but according to MSDN, you should be able to catch that event. Check out the WM_NCLBUTTONDOWN message (with HTHELP as the wParam). If not, try the WM_NCHITTEST message. One of those should result in something.
Luis
(3,307 Views)
