LabWindows/CVI
MultiFileSelectPopup not displaying files instantly when filetype is changed
I'm having a problem using the MultiFileSelectPopup. I'm using Labwindows/CVI 8.5.
The problem is: I try to support different file types for my application. But when I select a different file type the files are not displayed instantly. The file browser window simply stays white.
I'm calling it like this: MultiFileSelectPopup(folderOpen, "*.clf","*.clf;*.pdf;*.kml", Dialogues_Open_Data_File, 0, 0, 1, &numFiles, &fileList);
Default file type is CLF. When I load up the popup all CLF files are displayed correctly, but when I change to e.g. PDF there aren't any files in the display. However the files are displayed after I switch out of the folder and go back in.
Is there anything I can do to fix this behaviour?
(4,308 Views)
Hi Excaliburn,
I tried to reproduce your problem, but it worked fine on my computer.
This is what I wrote:
void main(void)
     * Local Variable Declarations:
    int numFiles;
    char** fileList;
    MultiFileSelectPopup("", "*.cws","*.cws;*.c;*.ini", "Test", 0, 0, 1, &numFiles, &fileList);
I also tried with different extension types and folders, but it always worked fine.
Maybe I didn't understand exactly what you mean. If that is so, then please give me some more detail.
(4,282 Views)
I have the same problem.
I found out that it only happens when you use the Excel Report instrument in order to access an xls file.
The MultiFileSelectPopup works fine at start but after creating a report file it fails as you described here.
Any solution?
Thanks.
(4,071 Views)
Found a solution:   http://digital.ni.com/public.nsf/allkb/9ABC70E8B641B60686256DEA005C7A49  Why Don't FileSelectPopup or MultiFileSelectPopup Dialogs Refresh Files Correctly?
(4,044 Views)
