LabWindows/CVI
MultiFileSelectPopup
Hye,
In fact when I make call with the MultiFileSelectPopup function, under Windows NT the popup appears correctly, but when I use it under Windows 2000 pro the popup is not complete. Indeed, under Windows 2000, it misses button OK, Remove and Remove All. I can only make the files pass in the Selected Files window, but as button OK does not exist, I cannot validate these files...
I need help. How can I solve this problem?
Bonjour,
En fait lorsque je fais appel à la fonction MultiFileSelectPopup, sous windows NT la popup apparait correctement, mais lorsque je l'utilise sous windows 2000 pro la popup n'est pas complète. En effet, sous windows 2000, il manque le bouton OK, le Remove et le Remove All. De ce fait, sous windows 2000, je ne peux que faire passer les fichiers dans la fenetre Selected Files, mais vu que le bouton OK n'existe pas,je ne peux pas valider ces fichiers...
On dirait que le probleme ne vient pas de Labwindows CVI, ais plutot de la version de Windows. Comment est il possible de remédier à cela?
Cordialement
Thomas Gambier
thomas.gambier@wanadoo.fr
(4,401 Views)
What version of LabWindows CVI are you using?
I get OK, Remove, and Remove All under CVI 6.0, Windows 2000 Pro, Service Pack 4.
(4,390 Views)
I've got Labwindows CVI v5.5? How is it possible that it's work for you and not for me?
(4,387 Views)
There is a patch for LabWindows 5.5 which you can download here:
http://digital.ni.com/softlib.nsf/websearch/090082BECD7AC973862568EA005704EE
The ReadMe file has the following note.
"In some international versions of Windows, the popup dialogs that
correspond to the OpenDirSelectPopup, MultiFileSelectPopup, and
FileSelectPopup functions were sometimes missing or misplacing
control buttons."
(4,382 Views)
Thank you so much for your help!
I'm going to try this patch...
I will give you some feed back of my attempt.
(4,377 Views)
Its Works!!!
Thank you again.
I wish I could help you next time!
(4,375 Views)
